Problem with line length.
corvuscorax4
i started to use free Qcad version few days ago and i like it a lot. I am using metric system. But noticed problem maybe somebody can help to solve it? I made drawing in mm add dimensions and everything looks good saved as .dxf but when i am opening .dxf file with other software the drawing is much bigger as it should be. It is in inches. in Qcad i made line 20mm in autocad i get 508mm same line. Where can be the problem what i am missing. I changed drawing units in mm in drawing and application preferences. Tried to reinstall QCAD but still getting same problem. Maybe somebody can help me to solve this problem?
Re: Problem with line length.
The settings in Application Preferences is meant for NEW drawings. To change the settings for the actual loaded drawing you have to change the Drawing Preferences. But note that that only change the unit name! If you need to convert an existing drawing from e.g. inch to mm you have to use the Convert Unit tool below Menu / Edit / Convert Drawing Unit.corvuscorax4 wrote: ↑Wed Aug 25, 2021 9:20 amI changed drawing units in mm in drawing and application preferences. Tried to reinstall QCAD but still getting same problem. Maybe somebody can help me to solve this problem?
corvuscorax4
i am only testing this program write now. I need to change units for all feature drawings. Is it possible to change units one time and forever. Or i need convert units and make some other options every time?
corvuscorax4
after i set units to mm and creating new drawing i am still getting .dfx file in inch. In QCAD all dimensions are good but in other software in inch.
Please attache a QCAD mm drawing which shows up in other application as an inch drawing to see what is going on. Thanks.
corvuscorax4
I attached drawing it should be 20x20mm square. It is in QCAD but in other software i get 508x508mm square.
- test2.dxf
- (26.04 KiB) Downloaded 683 times
Thanks for the test drawing.
However - it seems to me that your "other software" has an issue. Maybe you need to adjust the units in that software before you load a drawing or it has a general problem with the dxf format which is in QCAD CE the dxf R15 format.
For testing: I saved your test drawing with QCAD Professional as a R27 dxf format. Please check with your "other software" how it works regarding the unit.
I tested the drawing in three different CAD software packages. Range from Freeware to High end. Every software was able to load the drawing, unit was always mm and the rectangle was rendered 20 by 20. With other words - worked like a charm.corvuscorax4 wrote: ↑Thu Aug 26, 2021 5:32 amI attached drawing it should be 20x20mm square. It is in QCAD but in other software i get 508x508mm square.
corvuscorax4
Thank you for yuor help. I tried your file on solidworks edrawings program and i still get same dimensions. But today i tried on work computer with autocad and there was everything ok so i think problem is with edrawings. If there is problem with this software only then it is ok for me because this is not my main program. In a few days i will test with other software and let you know how it works.
- test2_mod.jpg (105.46 KiB) Viewed 11494 times
Deal!corvuscorax4 wrote: ↑Thu Aug 26, 2021 5:52 pm... In a few days i will test with other software and let you know how it works.
