[solved] Right Mouse Button
sleepycat
Post by sleepycat » Wed May 05, 2021 2:01 pm
This morning I installed QCAD Trial for Windows and, when the trial ended, I removed the specified plugin files to continue using QCAD Community Edition. However, when I restart QCAD I no longer have a right mouse button.
I have tried with both 64bit and 32bit, same issue. Is the right mouse button a PRO feature?
Many thanks, Andy
O/S: Windows 10 Pro, version 20H2
Version: 3.26.2.0 (3.26.2)
Internet: QCAD.org
Build Date: Apr 13 2021
Revision: 57092ea
Qt Version: 5.13.2
Architecture: i386
Compiler: Unknown
ryancousins
Re: Right Mouse Button
Post by ryancousins » Wed May 05, 2021 2:26 pm
Welcome to the Forum!
If you are referring to the context menu, you are correct. That is not available in the community edition. The right mouse button will still function to back out of tools that are currently engaged.
Here is a list of features. The ones in blue are available only in the Pro version.
https://qcad.org/en/documentation/features
sleepycat
Post by sleepycat » Wed May 05, 2021 2:42 pm
Brilliant, thanks for confirming that, much appreciate your swift reply.
