[solved] Saving as a .DWG
danro
Post by danro » Thu Apr 15, 2021 4:05 pm
Hi All.
I'm VERY new to QCAD and while I have succeeded once, I'm unable to recreate it.
I was advised to use QCAD as it takes both .DXF and .DWG formats as inputs and outputs - most of my drawings are .DXF and I'm needing some in .DWG format.
I'm using Ubuntu 20.04.2 LTS and I've installed the Community Edition of QCAD version 3.26.1.0
After installing I removed the "pro" modules as instructed in the right hand panel.
Could my initial success be related to not closing down and restarting QCAD?
Anyway, now when I try to save a new drawing I'm only offered
"R15 [2000/LT2000] DXF Drawing [dxflib"] (*.dxf)"
In the format drop down box of the save window (image attached)
And when I try to open the .DWG QCAD created for me from the recents list I get the message in the second attachment "No suitable Importer found. Please check file format and extension"
Am I doing something wrong or have I misunderstood what QCAD has to offer?
Many thanks in advance for your help
The only option when I try to save something
QCAD-saving options.png (24.7 KiB) Viewed 10129 times
Message when I try to open the file QCAD created
Re: Saving as a .DWG
Post by andrew » Thu Apr 15, 2021 4:09 pm
I've moved this topic to the appropriate QCAD Community Edition forum.
The QCAD CE only supports DXF.
See also:
https://qcad.org/en/documentation/features
danro
Post by danro » Thu Apr 15, 2021 4:23 pm
Yes I went back and reread the offerings, my mistake.
Thank you for your prompt reply.
