[Solved] N line number increment
Daniel4
Post by Daniel4 » Sat Jan 30, 2021 6:11 pm
I am in the need of two variables that increment by 1, each time they are called up.
I am using the 'N' linenumber as as one of the variables.
I made another variable in the JS file, and called it eventnumber.
It does show in the post, but does not increment.
I have some screenshots attached for reference.
Thank you.
P.S. Sorry if these files are not well organized, or if I am missing out something that I should have included.
Running Windows 10, QCad/Cam version 3.25.2.4
Test Post.dxf
(109.35 KiB) Downloaded 665 times
PT4.js
(826 Bytes) Downloaded 685 times
GCode2AxisPT.js
(10.81 KiB) Downloaded 661 times
Eventnumber screenshot.jpg (30.66 KiB) Viewed 7635 times
Thisrapidmove screenshot.jpg (43.39 KiB) Viewed 7635 times
Eventnumber does not increment.jpg (59.1 KiB) Viewed 7635 times
Re: N line number increment
Post by andrew » Mon Feb 01, 2021 1:56 pm
You'd have to detect when [E] gets written and increment accordingly:
GCode2AxisPT.prototype.writeBlockFromString = function(blockStrings) {
    if (isNull(blockStrings)) {
        return;
    if (isString(blockStrings)) {
        blockStrings = [ blockStrings ];
    // detect usage of [E]
    var incE = false;
    for (var i=0; i<blockStrings.length; i++) {
        // blockString
        // e.g. "[N] G01 [X] [Y]"
        var blockString = blockStrings[i];
        if (blockString.contains("[E]")) {
            // a block string contains variable [E], increment after writing
            incE = true;
    // write block strings:
    CamExporterV2.prototype.writeBlockFromString.call(this, blockStrings);
    if (incE) {
        this.eventNumber+=this.eventNumberIncrement;
This is overly complicated and we will add a function to detect variable usage more easily. This will work with QCAD/CAM >= 3.25.2.11:
GCode2AxisPT.prototype.variableUsed = function(id, value) {
    if (id==="E") {
Daniel4
Re: [Solved] N line number increment
Post by Daniel4 » Wed Feb 03, 2021 2:41 am
Wow Andrew!
I have no idea how you did that. it works perfect, thanks!
I could have never figured that out.
