ISO Metric Engineering Templates
About the creation of DXF / DWG part library items.
Clive
Moderator
Post by Clive » Fri Jun 08, 2012 4:27 pm
ISO eng. A3 metric template
Hi Guys
I have slightly modified the QCAD ISO eng. A3 metric template.
In the attached dxf file you will find that I have added a Notes section and have enclosed the border. As well as creating 'editable' blocks out of the Notes, Revision and Title blocks which will show up in the block list. You can simply edit these to suit your needs ('double-click' to open the block in its own window -then you can change it).
I have also added AEC layers, again which will show in the layer list.
To use the template simply save it to your templates folder.
Hope its useful. :wink:
ISO eng A3 metric template (modified).dxf
(84.59 KiB) Downloaded 6430 times
Modified ISO A3 eng. Template.png (51.8 KiB) Viewed 93514 times
Clive
Moderator
ISO A4 Engineering Templates
Post by Clive » Sun Jun 10, 2012 5:39 pm
Hi Guys
Please find attached two A4 ISO metric templates in Portrait and Landscape which I have modified from the QCAD metric ISO A4 template. Each template comes complete with AEC layer standards and a choice of blocks to use - Revision , Title and a compact 80 mm x 80 mm 'handy' title block.
Simply 'double-click' the blocks in the block list to edit and add your own information to suit your own needs.
Hope its useful :wink: .
ISO eng A4 metric templates.zip
(19.96 KiB) Downloaded 7693 times
ISO A4 eng Templates.png (52.47 KiB) Viewed 93493 times
Clive
Moderator
ISO A2 Engineering Template
Post by Clive » Mon Jun 11, 2012 4:17 pm
Hi Guys
Please find attached An ISO A2 eng. metric template which I have modified from the QCAD ISO A2 metric template.
The template comes complete with - Notes block, Revision block, Title block, 'Handy' 80mm x 80mm title block - all of which you can modify and edit to suit your own needs!
The template also includes AEC layers.
ISO eng A2 metric template.dxf
(105.31 KiB) Downloaded 4122 times
ISO A2 eng. metric template.png (32.39 KiB) Viewed 93485 times
Clive
Moderator
ISO A1 Engineering Template
Post by Clive » Tue Jun 12, 2012 3:44 pm
Hi Guys
Please find attached an ISO A1 eng. metric template with Notes, Revision, Title and 'Handy' title blocks - just edit to suit your own needs.
The template comes complete with AEC layers.
ISO eng A1 metric template.dxf
(117.73 KiB) Downloaded 4010 times
ISO eng A1 metric template.png (29.09 KiB) Viewed 93409 times
Clive
Moderator
Re: ISO A0 eng. metric template
Post by Clive » Wed Jun 13, 2012 4:47 pm
Hi Guys
Here is the last of the metric templates that I have modified from the QCAD metric templates. It comes complete with Notes, Revision, Title and 'Handy' title blocks, which you can edit to suit your own needs. This template also comes complete with AEC layers.
ISO eng A0 metric template.dxf
(131.72 KiB) Downloaded 3742 times
ISO eng A 0 metric template.png (26.28 KiB) Viewed 93376 times
Return to “Creating DXF/DWG items”
