SOLVED Block changes angle when selecting to insert
I prepared a block and saved it, but when I try to insert it, the angle is different.
- Block problem 2.png (32.45 KiB) Viewed 9046 times
- Block problem.png (181.87 KiB) Viewed 9046 times
On Win 11 64 bit, QCAD Pro Version: 3.32.2.0 (3.32.2)
Re: Block changes angle when selecting to insert
Blocks can be rotated or scaled while inserting them. Please check the options toolbar at the top while inserting the block. You likely want the scale to be 1 and the rotation to be 0.
Re: SOLVED Block changes angle when selecting to insert
Thank you! I had that problem before and abandoned the attempt. I need to be more observant as I had not realized that that line was there.
