Seeking Assistance with dxflib Library Issues
If you are having problems with dxflib, post here. Please report bugs here.
yan
Post by yan » Tue Aug 06, 2024 3:43 am
I’ve been experiencing issues with the export of filled patterns in DXF files using dxflib. The patterns are not displaying correctly in the recipient CAD software, and I am at a loss as to how to resolve this problem. I have tried various troubleshooting steps, including checking DXF version compatibility, verifying the fill pattern definitions, and adjusting coordinate systems, but the issue persists.
Re: Seeking Assistance with dxflib Library Issues
Post by CVH » Tue Aug 06, 2024 6:43 am
Perhaps have a look at: https://www.qcad.org/rsforum/viewtopic.php?f=20&t=9762
And all linked.
Exporting to AC1015 format?
If the selected circle is hatched with ANSI32 then I suspect that the scale is too small making it look filled as solid.
yan
Post by yan » Tue Aug 06, 2024 6:57 am
I tried adjusting the scale, which was originally 1, and changed it to 1, and then the display became normal.。It's not normal when I open it, but it will show normally after I switch the pattern.
yan
Post by yan » Tue Aug 06, 2024 7:09 am
yes,AC1015
Post by CVH » Tue Aug 06, 2024 7:45 am
Your best option is probably comparing the dxflib export with a DXF saved by QCAD containing a circular hatch textual.
I suspect that the hatch records should match.
I am not aware what the target application does when you force scale = 1.0 ...
It could be that the hatch is regenerated over new and then all would be OK of course.
Changing a property with the QCAD GUI has mostly no effect when the difference is too small or zero.
In one of my replies in the linked topic I point out that I don't know what the trailing parameters are for.
DL_HatchData data(1, true, 1.0, 0.0, pattern, 0.0, 0.0);
https://qcad.org/doc/dxflib/2.5/classre ... _data.html
Perhaps you could share the code that constructs the circular hatch and Andrew can have a look at it.
Or contact him directly.
Report back when solved ... That could be helpful for other dxflib users. :wink:
You should be aware of dxflib licensing agreements: https://qcad.org/en/90-dxflib
yan
Post by yan » Tue Aug 06, 2024 9:06 am
When I open the file with QCAD, it shows solid fill. Why is this
Post by CVH » Tue Aug 06, 2024 9:15 am
As in my reply above ...
Perhaps you could attach code, an example file, a corrected file by the source application ...
Without, we can only try to guess what could be the issue.
I also think that QCAD or the other application will fall back on SOLID filled when there are errors.
Or without the required hatch pattern installed or a virtual copy in the DXF file.
Although the linked topic was tagged as 'SOLVED', I did find an invalid hatch in the returned DXF file.
yan
Post by yan » Tue Aug 06, 2024 9:26 am
DL_HatchData hatchData(1,false,100,0,"ANGLE");
std::vector<std::vector<DL_HatchEdgeData>> loopDatas;
std::vector<DL_HatchEdgeData>loop;
DL_HatchEdgeData edgeData1(0, 0, 100, 0, M_PI, true);
DL_HatchEdgeData edgeData2(0, 0, 100, M_PI, 2*M_PI, true);
loop.push_back(edgeData1);
loop.push_back(edgeData2);
loopDatas.push_back(loop);
Post by CVH » Tue Aug 06, 2024 10:04 am
Rather different from: https://github.com/qcad/qcad/blob/maste ... b/main.cpp
I don't see you end the loop, end the hatch ...
yan
Post by yan » Tue Aug 06, 2024 10:20 am
void WriteToDxf::WriteHatch(const SGObjHatch* hatch, DL_Dxf& dxf, DL_WriterA* dw)
if (hatch == nullptr)
return;
DL_HatchData hatchData = hatch->getDL_HatchData();
DL_Attributes attributes = getDL_AttributesFromSGDrawBaseObj(hatch);
dxf.writeHatch1(*dw, hatchData, attributes);
std::vector<std::vector<DL_HatchEdgeData>>loopData;
loopData = hatch->getLoopData();
for (int i = 0; i < loopData.size(); i++)
std::vector<DL_HatchEdgeData> loop = loopData;
// Write hatch loops:
DL_HatchLoopData lData(loop.size());
int type = loop[0].type;
int curveSize;
AnyCurve2d* polyLine;
if (type == 0)
polyLine = hatch->calLoop(loop);
curveSize = polyLine->curveCount();
lData.numEdges = curveSize;
dxf.writeHatchLoop1(*dw, lData);
// Write hatch loop edges:
for (int k = 0; k < loop.size(); k++)
DL_HatchEdgeData shape = loop[k];
// line:
type = shape.type;
if (type == 0)
for (int i = 0; i < curveSize; i++)
LineSegment2d* line = dynamic_cast<LineSegment2d*>(polyLine->getBoundCurve(i));
Arc2d* arc = dynamic_cast<Arc2d*>(polyLine->getBoundCurve(i));
if (line != nullptr)
Point2d startPt = line->startPoint();
Point2d endPt = line->endPoint();
dxf.writeHatchEdge(
*dw,
DL_HatchEdgeData(startPt.x(),
startPt.y(),
endPt.x(),
endPt.y()));
if (arc != nullptr)
Point2d center = arc->getCenter();
double radius = arc->getRadius();
dxf.writeHatchEdge(
*dw,
DL_HatchEdgeData(center.x(),
center.y(),
radius,
arc->getStartAngle(),
arc->getEndAngle(),
arc->isAntiClock()));
break;
if (type == 1)
dxf.writeHatchEdge(
*dw,
DL_HatchEdgeData(shape.x1,
shape.y1,
shape.x2,
shape.y2));
// arc:
if (type == 2)
dxf.writeHatchEdge(
*dw,
DL_HatchEdgeData(shape.cx,
shape.cy,
shape.radius,
shape.angle1,
shape.angle2,
shape.ccw));
// full circle:
/*QSharedPointer<RCircle> circle = shape.dynamicCast<RCircle>();
if (!circle.isNull()) {
dxf.writeHatchEdge(
*dw,
DL_HatchEdgeData(circle->getCenter().x,
circle->getCenter().y,
circle->getRadius(),
0.0,
2 * M_PI,
true));
// ellipse arc:
if (type == 3)
dxf.writeHatchEdge(
*dw,
shape.cy,
shape.mx,
shape.my,
shape.ratio,
shape.angle1,
shape.angle2,
shape.ccw));
// spline:
if (type == 4)
dxf.writeHatchEdge(
*dw,
DL_HatchEdgeData(shape.degree,
shape.rational, // rational
shape.periodic,
shape.knots.size(),
shape.controlPoints.size(),
shape.fitPoints.size(),
shape.knots,
shape.controlPoints,
shape.fitPoints,
shape.weights,
shape.startTangentX,
shape.startTangentY,
shape.endTangentX,
shape.endTangentY
/*Geometry2dUtils::radToDegree(shape.startTangentX),
Geometry2dUtils::radToDegree(shape.startTangentY),
Geometry2dUtils::radToDegree(shape.endTangentX),
Geometry2dUtils::radToDegree(shape.endTangentY)*/
//std::vector<DL_HatchEdgeData>splineData;
//splineData.push_back(shape);
//AnyCurve2d* spLine = hatch->calLoop(splineData);
//if (spLine == nullptr||spLine->curveCount()==0)
// continue;
//BezierCurve2d* bezierCurvePtr =dynamic_cast<BezierCurve2d*>(spLine->getBoundCurve(0));
//BSpline2d* spLinePtr=nullptr;
//if (bezierCurvePtr == nullptr) {
// spLinePtr = dynamic_cast<BSpline2d*>(spLine->getBoundCurve(0));
//else {
// std::vector < Point2d > vecPts=bezierCurvePtr->getInterpolatePoints(20);
// int size = (int)vecPts.size();
// if (size < 2)
// return;
// Vector2d vStart = vecPts[1] - vecPts[0];
// Vector2d vEnd = vecPts[size - 1] - vecPts[size - 2];
// spLinePtr = new BSpline2d(vecPts, vStart, vEnd);
//if (spLinePtr == nullptr)
// continue;
//Vector2d startTangent = spLinePtr->getStartTangent();
//Vector2d endTangent = spLinePtr->getEndTangent();
//std::vector<Point2d> fitVec=spLinePtr->getFitPointVec();
//std::vector<Point2d> controlVec=spLinePtr->getControlPointVec();
//std::vector<double> knotVec=spLinePtr->getKnotsVec();
//std::vector<double> weightVec=spLinePtr->getWeightVec();
//std::vector<std::vector<double> >controlVecd;
//std::vector<std::vector<double> >fitVecd;
////knotVec.clear();
//for (auto& pt : controlVec) {
// std::vector<double> tempVec;
// tempVec.push_back(pt.x());
// tempVec.push_back(pt.y());
// controlVecd.push_back(tempVec);
//for (auto& pt : fitVec) {
// fitVecd.push_back(tempVec);
//dxf.writeHatchEdge(
// *dw,
// DL_HatchEdgeData(shape.degree,
// shape.rational , // rational
// shape.periodic,
// knotVec.size(),
// controlVec.size(),
// fitVec.size(),
// knotVec,
// controlVecd,
// fitVecd,
// weightVec,
// Geometry2dUtils::radToDegree(startTangent.x()),
// Geometry2dUtils::radToDegree(startTangent.y()),
// Geometry2dUtils::radToDegree(endTangent.x()),
// Geometry2dUtils::radToDegree(endTangent.y())
dxf.writeHatchLoop2(*dw, lData);
dxf.writeHatch2(*dw, hatchData, attributes);
yan
Post by yan » Tue Aug 06, 2024 10:21 am
Are there any errors in the above?
Post by CVH » Wed Aug 07, 2024 8:20 am
Please put long code in a code panel with the [</>] button.
Now it took some time to re-format the text before it was readable to me.
I am not a specialist on this matter and C++ looks a bit different than JS
From your code I presume that the circular boundary is not exported as a full circle.
That part is ruled out.
The origin is thus the first part of your code and I presume this is intended to export polyline edges.
For a single polyline because the edges loop is terminated with a break afterwards.
There is also something about Arcs in DXF.
It is clear that RDxfExporter diversifies between reversed or not:
https://github.com/qcad/qcad/blob/maste ... .cpp#L1467
I have a problem with understanding:
- cycling loopData with i but the index is not used.
- cycling loop = loopData with k
- cycling curveSize nested but again with i
For the rest I can't detect anything wrong but again, I am not a specialist on this matter.
Also discovered what the trailing parameters stand for.
They define the pattern origin, a most important feature for patterned hatches.
https://github.com/qcad/qcad/blob/maste ... .cpp#L1434
Presumed it but it is not explained as such in the reference:
yan
Post by yan » Wed Aug 07, 2024 9:30 am
Thank you for your reply, you gave me a lot of tips and help
Return to “dxflib Troubleshooting and Problems”
