Sir,
I am not able to get the appropriate version for .cnc file extension for our cutting machine.
Error shows when we send path to pen drive
Error display shows: arc length too long : 0
then we extract file from Pronest 8 and covert nested file then in is working properly from Pronest software.
Kindly help
Not able to export compatible file .cnc version to our cutting machine after nesting
Re: Not able to export compatible file .cnc version to our cutting machine after nesting
Please provide more details:
- What post processor do you use?
- What type of machine / controller do you have?
- Please attach your files: the output from QCAD/CAM, a file that is known to work, your DXF file
Note that the extension .cnc is used by many different G-Code dialects and is no indication that a file will work with your particular controller.
