[solved/fixed] Block attributes lost on saving
If you are having problems with QCAD, post here. Please report bugs through our Bug Tracker instead.
Always attach your original DXF or DWG file and mentions your QCAD version and the platform you are on.
spatz
Post by spatz » Wed May 21, 2025 8:29 pm
I have a drawing with block including 7 attributes. On saving I get an error message on command line telling me: "Exception occurred. Entity NOT saved: <ID of block>". When opening the file again there is only one attribute left in block reference. To reproduce the error I synchronized the attributes (shortcut "UA") and changed the attribute values via property editor. The problem persists.
I copied the block from original file into an empty file and still could reproduce the error. My observations:
1. Layer of block reference is changed to "0" on saving
2. The attribute that is left isn't always the same, when I reproduce the error
3. I could change few attributes without getting the error but after changing at least 5 attributes the error again occurs
Does anyone have an explanation for this error?
Stephan
file:
Test_Schriftfeld.dxf
(102.37 KiB) Downloaded 229 times
screenshot before saving:
screenshot after opening:
OS:
GNU/Linux Debian 13 (6.12.27-amd64)
QCAD:
Version: 3.32.2.0 (3.32.2)
Revision: 6616def
Qt Version: 5.14.2
Architektur: x86_64
Compiler: gcc 5.4.0
Re: Block attributes lost on saving
Post by andrew » Thu May 22, 2025 10:55 am
Thank you for your report.
Bug report at:
https://www.qcad.org/bugtracker/index.p ... sk_id=2673
As a workaround, you can edit the block attributes each individually (select one by one) or double-click them to edit.
spatz
Post by spatz » Thu May 22, 2025 7:50 pm
Thank you, Andrew, for immediately reviewing and fixing this problem.
Stephan
Return to “QCAD Troubleshooting and Problems”
