Hi from Denmark
Post to this forum to introduce yourself to this forum if you are new here. You might want to include some information about the work you are doing or planning to do with QCAD.
Duncan Lithgow
Hi from Denmark
Post by Duncan Lithgow » Tue Oct 20, 2020 6:23 pm
Hi there. I've bought QCAD since it supports GNU software and was recommended by Yorik (the FreeCAD guy). LibreCAD is a great project but just too basic and I need DWG support.
So I'm here to learn, for now by using it for a roof renovation I'm working on at home. Normally I use Autodesk Revit & AutoCAD at work so there are some things I'm having trouble getting used to.
I'm also active at osarch.org where we're trying to expand and support FOSS AEC software. QCAD & LibreCAD are important tools for that workflow for the many, many projects that don't need 3d.
So, glad to be here, see you in other parts of the forum. Here's my first question:
https://www.ribbonsoft.com/rsforum/view ... a39#p29913
Return to “Introduce Yourself”
