[solved] Rulers in margins
Posted: Sat May 22, 2021 7:03 pm
by mogur
Noob here. Win10, Qcad 5.13.2. Just a day or two into the learning curve, but my rulers in the margins have disappeared. So, I fumbled around until I found-
Edit, Application Preferences, Graphics View, Appearance. Under Rulers and Scrollbars, there are two checkboxes, Show Rulers and Show Scrollbars. Both are checked. I have exited and re-entered Qcad many times checked and unchecked both boxes, and although the scrollbars show up, the rulers do not. Is there a magical incantation I'm missing?
EDIT: oops, just noticed this is the pro version forum. Forgive me, and would a mod please move this post to the free version forum? Thanks.
Re: Rulers in margins
Posted: Sat May 22, 2021 7:55 pm
Please check the Grid settings below "Drawing Preferences". They are set to "Auto"?
Thanks - done. :wink:
Re: Rulers in margins [solved]
Posted: Sat May 22, 2021 11:05 pm
by mogur
Thank you so much, Husky. I am happy to report that the minute I changed the Port 1 Grid and MetaGrid settings from 'auto' to arbitrary 'fixed' values, the rulers display came back. I am a bit startled by their appearance, though, in that my logic has a bit of a problem grasping why grid settings would affect ruler display, but so be it. Resetting the grids to 'auto' did not make the rulers disappear again, so I will continue with my learning curve, only slightly perplexed by this behavior.
Husky, you are a hero. And thank you also for your kind welcome post in the Introduction forum.
