Layer configuration for CAM?
Posted: Fri Jan 14, 2022 11:28 am
I want to define some layers for automatic CAM generation and I can't find where to do this. Seems that the things has changed and I can't find the "Configuration Options (per layer)" anymore:
It is possible to create templates for automatic CAM generation in QCAD/CAM? I want for example that all the shapes from the layer "Contour_14" to be cut on outside with a 14mm deep cut.
Best regards.
Best regards.
