Hi, using Windows 11 Pro, QCADCAM V 3.31.1.0
Are the feed rates (feed per rev) units in mm/rev or inches per rev
Similarly are the plunge rates (penetration rate) in mm/minute or inches per minute
I guess both of these depend on your unit settings in the document properties or in the CAM Config (mine states mm).
Sorry new user question.
Barry
Feed Rate and Plunge Rate - Tool Settings
Bazer_20002000
Re: Feed Rate and Plunge Rate - Tool Settings
These values are copied 1:1 to the G-Code output of your post processor (e.g. a feedrate of 100 yields G-Code output F100). Please enter the values exactly as you want them to appear in the G-Code file.
Some controllers support different feedrate modes, for example G94 (units per minute) or G95 (units per revolution). Please refer to your controller manual to see what is supported by your controller. Default is usually units per minute.
And 'units' depend on G20 (inches) or G21 (mm)
One of G20-G21 and G93-G94-G95 are usually included in a header.
Otherwise the controller uses its defaults.
Please note that a standard post-processor may not always include these, but they are highly customizable.
The drawing unit is not directly tied to a G-Code.
CAD is basically unit-less, the unit is nothing more than how you name a value.
Then 1 unit can be 1mm, 1inch or 1km, a light-year .... In short 1.0000... something
Exporting a 10.0 by 10.0 rectangle in G-Code can then in mm or in inches depending G20/21.
Bazer_20002000
Many thanks, being a retired scientist I have have spent most of my life with the unit of time as seconds. Knowing its selected unis / minute certainly helps and seems to be sensible.
cheers
Barry
cheers
Barry
Units per minute is also handy because the spindle speed is universal in revolutions per minute.
Avoiding a factor 60 or 0.01666... in many calculations like chip-load, cutting edge speed and so on.
