Nesting just completely broken
Posted: Fri Dec 29, 2023 10:42 pm
by regattaguru
Version info:
Version: 3.28.2.0 (3.28.2)
Internet: QCAD.org
Build Date: Aug 31 2023
Revision: a8039fc
Qt Version: 5.14.2
Architecture: x86_64
Compiler: Clang 10.0.0
OS: MacOS 14.2.1 (23C71)
Hardware: MacBook Pro 14-inch, 2021
While once the Nesting feature was decent if slow, now it does nothing useful at all. It will now not nest even trivial cases, often not fitting more than 30% of the pieces when 200% will fit.
Re: Nesting just completely broken
Posted: Sat Dec 30, 2023 3:07 am
Sounds like the Qcad configuration is somehow damaged. If you can't figure what could be set wrongly try to reset Qcad to its defaults.
https://qcad.org/en/tutorial-resetting- ... figuration
Posted: Sat Dec 30, 2023 7:17 am
Your Nesting preferences look fine.
They probably include 'Disable AppNap' because you are working on a MacBook, on Windows this preference does not exist.
I remark one Nesting Option in the option Toolbar where I have some reservations about.
Tolerance = 100
Even with a trivial rectangle to nest in a larger rectangle I get no solutions with that amount of tolerance.
The default value 0.001 works fine in most common cases.
We could help you more efficiently with an example drawing file.
Rather weird that a huge tolerance give less good results.
And true, a full configuration reset would revert to the CAM nesting default tolerance ...
... But you will loose all other QCAD(/CAM) customization's, user preferences and persisting options in doing that.
Posted: Sat Dec 30, 2023 8:33 am
regattaguru: Please try the following options:
Tolerance: 1
Strategy: Align
If you cannot solve the issue, please attach or e-mail your DXF file, so we can help efficiently. See also forum rules in red at the top. Thanks.
