CAM Export questions
Posted: Wed May 31, 2023 2:24 pm
Hello QCAD/CAM team, I'm new at this forum.
I created DXF files with only lines to cut, then I export file using LinuxCNC postprocesor.
I would like to reduce cut time, I mean reduce rapid movement lenth between points.
Question 1
I use LinuxCNC Postprocesor to create path. It works fine.
I see that QCAD use always start point of the line as first point to cut.
Is possible to change that default settings to use end point of the line
as first point to cut?
Or use nearest line point (start or end) to set as start cut point?
I ask because this idea can make shorter total cutting time.
Diagonal is longer than straight line
See my screenshots. In green new view
Thank you!
Question 1
Thank you!
