Old version of Qcadcam not sure if its still supported but here goes.
Version:
3.18.1.0 (3.18.1)
Internet:
QCAD.org
Build Date:
Oct 4 2017
Revision:
24e23aa
Qt Version:
5.8.0
Architecture:
x86_64
Compiler:
gcc 4.8.1
Running on Dell T7600 w/ Ubuntu 22.04
using the Lxcnc post.
When creating the code at setting the side (inside/outside) the selection is met with a requirement from the postprocessor "Postprocessor requires lead in / lead out for cutter radius compensation".
I know I am getting older but at the end of last year I remember this post not requiring any of this an not putting a G41 in the files.
Jim
postprocessor outputing G41 code
- Full Member
- AA-PPross-LxcncIn.ngc
- (450 Bytes) Downloaded 870 times
Re: postprocessor outputing G41 code
I can confirm that this post processor indeed outputs G41/G42 for tool radius compensation.
Post processors that compute radius compensation (without the need for G41/G42) have "(Offset)" in their name.
Perhaps, you can open a file from last year to check what post processor you might have used then.
- Full Member
Andrew
Once again it looks like operator error. Too many files with the same name and something got over written..... So a deep dive into the archives might turn up the original..
Jim
Jim
- Full Member
Dell T7600
Ubuntu 22.04
Version: 3.18.1.0 (3.18.1)
Internet: QCAD.org
Build Date: Oct 4 2017
Revision: 24e23aa
Qt Version: 5.8.0
Architecture: x86_64
Compiler: gcc 4.8.1
The confusion has not be cleared but I found two files that didn't have the expected values.
The JimOffsetIn.js is what my old Lncncin.js had been until something shifted.
JimOffsetIn.js has this line this.outputOffsetPath = true;
GCodeBase.js has additional lines a line # 61 and 62 they define the name of the input file and path used in the header.
Jim
Ubuntu 22.04
Internet: QCAD.org
Revision: 24e23aa
Qt Version: 5.8.0
Compiler: gcc 4.8.1
Jim
Jim,
Remark that GCodeBase.js may be overwritten by an update of QCAD/CAM.
Please read the header of this file.
You should not edit that for customizing the G-code output.
LxcncIn.js nor JimOffsetIn.js are standard postprocessors.
JimOffsetIn.js should create an offset path instead of using G41/G42.
One can include any required customization in these files.
Both are based on GCodeIN.js what itself is based on GCodeBase.js
One can overrule any of the settings in GCodeIN.js or in GCodeBase.js by overwriting them in the custom postprocessor.
- Full Member
Back in 2019 Andrew was helping me develop a set of headers for my postprocessor. He gave me a block of code that listed the name and directory of the .dxf file in the gcode file. I am not sure who edited the GCodeBase.js code but the end result means the header info would be available to any postprocessor just as the file and path for the .ngc file is defined in the GCodeBase.js file.
https://qcad.org/rsforum/viewtopic.php? ... 387#p25387
Jim
Note: this is version 3.18.1
Jim
Jim,
The GCodeBase.js you posted on Thu Jul 27, 2023 9:24 pm
is not the original from QCAD/CAM
Yours start with:
That should be:
Yours is definitely altered and less complete if we compare it with originals.
The only way to revert back is by re-installing QCAD/CAM ...
One could temporarily install a trial version under a different name/folder and copy over the standard postprocessors.
Concerning topic 6700:
In the copies I have of GCodeBase.js the variables INFILENAME and INFILEPATH are declared but the writefile function does not include setting a value for these variables.
Concerning this topic:
What are the problems you still have?
Yours start with:
* Version 1 27jul23
* Include definition of class CamExporterV2 from QCAD/CAM plugin:
include("scripts/Cam/CamExportV2/CamExporterV2.js");
* This file is part of the QCAD/CAM software.
* Do NOT edit this file. Your changes will be lost when the software
* is updated or reinstalled.
* For details, please refer to the file README.txt in this directory.
- Full Member
No problems here. Everything is good and I am getting the output I expect.
Thanks for your concern
Jim
Jim
