Hello from Brisbane, Australia
Post to this forum to introduce yourself to this forum if you are new here. You might want to include some information about the work you are doing or planning to do with QCAD.
AllanD
Post by AllanD » Wed Jun 12, 2024 4:01 pm
Hi, I am a retired engineer and have only recently become aware of QCAD although I have been using cad programs for nearly 30 years. My first introduction was on Megacad which is remarkably like Qcad in its interface and operation. Before leaving work 12 years ago started using inventor. I lost access to those programs and had to find a substitute for my projects. I have been using Turbocad but never really warmed to its quirky way of doing things. For 3D work I am now using Freecad which is becoming better with every upgrade. Freecad is great for 3D stuff but not for 2D drawings. Then I found Qcad and it only took me about an hour to find my way around the tools.
Not sure if I should ask a question here but I found I couldn't open multiple windows (drawings) nor could I open two applications of it. Does it not have this function?
I had nearly finished a drawing and wanted to open another application with a shipping container to copy it to my drawing only to find that it overwritten my drawing. Is this what normally happens?
Cheers Allan
Re: Hello from Brisbane, Australia
Post by andrew » Wed Jun 12, 2024 4:22 pm
Hello and welcome to the QCAD forum.
You can open multiple drawings but not in multiple windows. The drawings are opened in tabs instead.
Please make sure that you do not open the same drawing file multiple times / with multiple applications as you might accidentally overwrite your changes. I'd recommend to also work with versioning (e.g. MyDrawing001.dxf, MyDrawing002.dxf, ...) increase the number with each larger change. Needless to say, a fully automatic backup to an external hard drive is imperative (Windows Backup, macOS Time Machine or similar.
John Hyslop
Post by John Hyslop » Thu Jun 13, 2024 1:27 pm
Hi Allan
Hello from Melbourne.. 😁 Semi retired here.
I too am a fan of FreeCad for 3d and Qcad for 2d.
Given up with AutoCad completely and Inventor will die on my next PC upgrade as autodesk don't renew perpetual licenses anymore "subscription only option" so stuck on version 2020 until it breaks 😉
Welcome & Enjoy the forum...
Cheers
John..
Return to “Introduce Yourself”
