Hello from Godalming in UK,
I am Marta and I have been using QCAD for few years to design a felt patterns for my school clubs. I need some help with add-on "trace bitmap".
So, I create a lots of flat patterns which I usually scan, import as jpg file and then trace with spline. It take a lot of time, so I researched about the automatic tracing process. I came across this info:
https://qcad.org/doc/qcad/latest/refere ... ge_en.html
I have pro version but I do not have a clue how to instal the add-on and where it find, as all informations attached to that article are a bit confusing.
Is there anybody who can guide me with this process ?
Kind regards
Marta
[solved] Bitmap Tracing
Marta
Re: Bitmap Tracing
Hi Marta - welcome to the forum.
If your Pro version is 3.27.7 or younger then the trace tool is already included in your version.
You can find it below:
Menu/Draw/Trace Bitmap
If your Pro is older than 3.27.7 then there is no way to upgrade only the trace addon - the only way is to update Qcad all together to the current version which is 3.29.4.
Marta
Re: [solved] Bitmap Tracing
Hi Husky,
Thank you for your advice, I have just updated my QCAD app. This time I bought CAD/CAM and I hope that I will hook it to my laser machine.
I have question about converting polyline in to spline but I think this question is for different part of the forum.
hope to speak you somewhere around here:)
kind regards
Marta
kind regards
Marta
