To copy entities from one drawing into another drawing, please proceed as follows:
1. Open both drawing files with QCAD.
2. Switch to the source drawing and select the entities you want to transfer.
3. Choose Edit > Copy (or choose Edit > Copy with Reference and click a reference point).
4. Switch to the target drawing and choose Edit > Paste
5. Click a position to place the entities in your drawing
Troubleshooting
The entities changed color when pasting.
If the source drawing contains a layer "A" which is red and the target drawing also contains a layer "A" but that is blue, this effect may occur. You can tick the option Overwrite layers in the options toolbar to overwrite layer "A" in this case, but be aware that this changes your target drawing.
A block reference changed its appearance / content when pasting.
If the source drawing contains a block "A" and another block "A" (with a different content) is also present in the target drawing, this effect may occur. Please make sure your block definitions are compatible, rename the block or tick "Overwrite Blocks" in the options toolbar to use the block definition of the source drawing for all references to block "A".
The pasted entities don't have the correct size / scale or are rotated.
If the source and target drawings use different units, QCAD converts the entities from the source to the target unit. Please check the drawing unit of both the source and the target drawing under Edit > Drawing Preferences > General > Drawing Unit.
It is also possible that the scale factor is not 1 or the rotation angle is not 0 in the options toolbar when pasting:
Copying Entities from one Drawing to Another
Tips and tricks you want to share with other users. Tutorials, user submitted documentation, etc.
Return to “QCAD Tips and Tutorials”
Jump to
- General
- ↳ Announcements
- ↳ Chat
- ↳ Site Feedback
- ↳ Pre-sales Questions
- ↳ Introduce Yourself
- QCAD Professional Version
- ↳ QCAD 'How Do I' Questions
- ↳ QCAD Suggestions and Feedback
- ↳ QCAD Voting Corner
- ↳ QCAD Troubleshooting and Problems
- ↳ QCAD Installation and Upgrades
- ↳ QCAD Programming, Script Programming and Contributing
- ↳ QCAD 'Script Add-On & Plug-in challenge' - Work in Progress
- ↳ Finished 'Ready to go' Scripts/Plug-in's
- ↳ QCAD Tips and Tutorials
- ↳ QCAD/CAM
- ↳ What do you use QCAD/CAM for?
- QCAD Community Edition
- ↳ QCAD Community Edition
- International Forums
- ↳ Français
- ↳ QCAD Professional
- ↳ QCAD/CAM
- ↳ QCAD Community Edition (Version 3)
- ↳ Deutsch
- ↳ QCAD/CAM
- ↳ Italiano
- ↳ QCAD/CAM
- ↳ Español
- ↳ QCAD/CAM
- ↳ Português
- ↳ QCAD/CAM
- ↳ Nederlands
- ↳ QCAD/CAM
- QCAD Book
- ↳ QCAD - An Introduction to Computer-Aided Design
- ↳ QCAD - Una Introducción al Diseño Asistido por Ordenador
- ↳ QCAD - Eine Einführung in computerunterstütztes Zeichnen (CAD)
- QCAD Part Libraries
- ↳ General
- ↳ Creating DXF/DWG items
- ↳ Creating SVG items
- ↳ Meta Data
- dxflib
- ↳ dxflib Suggestions and Feedback
- ↳ dxflib 'How Do I' Questions
- ↳ dxflib Troubleshooting and Problems
