[solved] No Reference Manual In Help Tab
jb55
Post by jb55 » Mon Nov 10, 2025 9:54 pm
Under the HELP tab, when I select the Reference Manual, there is nothing there.
My system: Operating System: Windows 11 Pro 64-bit
QUCAD/CAM Version:
3.32.4.0 (3.32.4)
Internet:
QCAD.org
Build Date:
Sep 4 2025
Revision:
d3aa6db
Qt Version:
5.13.2
Architecture:
x86_64
Compiler:
MSVC++ 14.0 (2015)
QCAD INSTALLER: qcadcam-3.32.4-pro-win64-installer.msi
Re: No Reference Manual In Help Tab
Post by andrew » Tue Nov 11, 2025 8:30 am
I cannot reproduce this problem here.
Please try this:
Exit QCAD/CAM and delete the folder:
c:\\Users\[your name]\AppData\Local\QCAD\ReferenceManual
jb55
Post by jb55 » Fri Nov 14, 2025 3:22 am
That worked, Thank you.
