Solved: Dimentioning rounds off measurements
If you are having problems with QCAD, post here. Please report bugs through our Bug Tracker instead.
Always attach your original DXF or DWG file and mentions your QCAD version and the platform you are on.
DShum
Post by DShum » Mon Feb 02, 2026 2:47 pm
Dimension problem - QCAB.png (290.64 KiB) Viewed 1652 times
Cabinets in center room.dxf
(111.24 KiB) Downloaded 6 times
On Win 11 64 bit, QCAD Pro Version: 3.32.6.0 (3.32.6)
Re: Dimentioning rounds off measurements
Post by CVH » Mon Feb 02, 2026 5:34 pm
Your drawing uses inches and Dimensions in fractional format with precision set to: Zero
See Drawing Preferences .. Dimension .. Dimension Settings .. Number format
Also inspect the same settings under Application Preferences for the default for all new drawings created with QCAD.
Once created see Drawing Preferences.
Return to “QCAD Troubleshooting and Problems”
