Length of arrows
CDL
Length of arrows
Post by CDL » Thu Dec 05, 2024 7:40 pm
Hello
-It would be very useful to add the property "Length" when we draw an arrow.
(Remark: When I draw an arrow, I don't understand the property "Courbe / Curve" ?)
- When we use the shortcut "MR" (without using the dialog box), it would be useful if we can check the option "Copy"
Thanks.
Re: Length of arrows
Post by CVH » Thu Dec 05, 2024 11:20 pm
The arrow size of a new Leader entity is by the overall Drawing Preference for Dimension arrows and Scale factor.
The property is "Spline" in English. Yes or No doesn't seem to make a difference.
Probably for supporting not QCAD native drawings that use a Spline instead of a Polyline.
In QCAD one can only specify a Polyline with straight segments.
A solution would then be to move/rotate a duplicate.
Select the entity(ies), DP & MR with almost the same effort.
Post by andrew » Fri Dec 06, 2024 12:18 am
Thank you for your suggestions.
The length property has been added for leader entities for the next release:
https://qcad.org/en/changelog
This has also been fixed for the next release. All tool options will be shown in the options toolbar for this tool when not using a dialog.
