Is there any documentation specifying the limits of the DXF AutoCAD 2002 (15.2) file format:
- max number of points, lines, splines...and so forth. (per layer ?)
- max number of layers.
- max file size
Many thanks for your help.
DXF AutoCAD 2002 (15.2) limits
I'm unaware of any relevant limit that would be enforced by the file format.
Theoretical limits enforced by object handles and data types exist of course but are exorbitant.
File size might be restricted by some older Windows file systems (FAT32) to about 4GB.
A DXF reference with general documentation about data types and fields is available from Autodesk: http://www.google.com/?q=dxf+reference
wit
Thanks for your quick answer.
So I'm investigating the upload process.
FYI, I'm using DXF format to upload point clouds, I need to investigate were the blocking limits are coming from.
