BDF CAD file format
This forum is a place where people can cast their vote for feature requests to be implemented from a selection of the top favorites submitted to the 'Bug tracker':
http://www.ribbonsoft.com/bugtracker/.
zadychladislav
BDF CAD file format
Post by zadychladislav » Wed Nov 14, 2018 8:53 pm
Hello
Im draving alot of drawing and it saved in my CNC on -> xxx.bdf <- format is any chance for future to open and save and open template on this BDF format . Thank you Ladislav
Re: BDF CAD file format
Post by andrew » Wed Nov 14, 2018 9:51 pm
Unlikely. I've never heard of that format before... If you can provide details or an example file, I can probably tell you more.
zadychladislav
Post by zadychladislav » Wed Nov 14, 2018 10:17 pm
Wow thank you so much for so faster answare
In attachment are two files one is BDF file and one is DXF file both are the same drawing.
For CNC WE USE BDF FILE CNC ARE ITALY PRODUCE NAME BIMATECH OR INTEAC FOR STONE & GLASS PROCESING
Both are in one zip.file becouse BDF I cant send alone by attachment.
REGARDS Ladislav
importa DXF & BDF.7z
Bdf & Dxf File in zip
(3.25 KiB) Downloaded 2225 times
Post by andrew » Wed Nov 14, 2018 10:45 pm
Unfortunately, this looks like a binary format (not human readable). This means that this cannot be supported for import or export in any way.
zadychladislav
Post by zadychladislav » Wed Nov 14, 2018 10:51 pm
Im using TechnoCad software and im opening easy check attachments
Post by andrew » Thu Nov 15, 2018 12:26 am
Sorry that I have not better news. Your best option is probably to find a converter from BDF to DXF or DWG or to find a CAD software that can import BDF and export DXF (perhaps the TechnoCad you are using can export to DXF).
Return to “QCAD Voting Corner”
