Force script path with env var or cli argument?
schmidtw
Post by schmidtw » Tue Oct 06, 2020 7:44 am
I'm looking to do some larger scale changes to scripts locally & would like to be able to point the same version of qcad to different instances of my script directories.
It's not completely clear how I should do this & the values that QT suggests are checked by default don't seem to be.
https://doc.qt.io/qt-5/qstandardpaths.html
AppDataLocation	"~/.local/share/<APPNAME>", "/usr/local/share/<APPNAME>", "/usr/share/<APPNAME>"
AppLocalDataLocation	"~/.local/share/<APPNAME>", "/usr/local/share/<APPNAME>", "/usr/share/<APPNAME>"
Any suggestions?
Thanks,
Wes
schmidtw
Re: Force script path with env var or cli argument?
Post by schmidtw » Thu Oct 08, 2020 7:24 pm
I did a fair bit of debugging and found that there are a few path searching blockers for being able to prefer one script tree over the built in version.
Here is my PR that fixes the issues I saw:
https://github.com/qcad/qcad/pull/26
